So im driving down the highway on my way to work. Going about 60mph in 5th gear. I try and accelerate to about 65 and notice every time i hit the gas there is a slight vibration, almost same the kind of vibration you get when your going too slow in a gear...that virbration. So i say lemme slow down and shift to 4th.
Slow down to and see if that helps, Im going maybe 45 in 4th gear, and still feel the vibration, I think maybe its something with the gears so I throw it in neutral let the car roll to a stop still feel INTENSE vibration. Also notice that as its vibrating the shifter is bobbing up and down (in neutral). I turn the car off check the tires, no flat. Start her up and pull off in 1st (seems ok) give more gas notice the vibration, hit a bump in the road and its shaking SO bad i cannot see out my rear view mirror.
Any idea's what I could be dealing with here?
2007 Saturn Sky just hit 60k miles, Manual, Cold air intake, no other mods. Never had a problem....till now
